T43 hinge sizes
T43 hinge sizes
My 15.0" T43 left hinge exploded when I opened the lid yesterday and I was wondering if the 14.1" hinge is the same size. I have a dead 14.1" that can serve as a donor, but I don't want to open my 15.0" all the way to find out they ares different sizes. Has anyone did this job previously?
Re: T43 hinge sizes
They seem to be different in the HMM, but maybe they are somewhat compatible. If anyone knows it would be of great help!
Re: T43 hinge sizes
I don't have a 15 inch to compare to but I highly doubt the 14 inch hinges would work, vast majority of cases they're made different. HMM backs that up.
You can certainly try though.
Your average ThinkPad collector.
Owns: T480, Yoga S1, modded T430, T61p (15.4"-GMA-WUXGA), R60e, T43 14" SXGA+, G40, T30 SXGA+, T23, A22p, T21, i1260, 600X, 770ED, 385XD, 560, PS/Note 425
Re: T43 hinge sizes
The 14.1 and 15" offerings are actually totally different monsters in terms of the lid assembly.Gonzaleitor wrote: ↑Thu Dec 28, 2023 5:04 pmMy 15.0" T43 left hinge exploded when I opened the lid yesterday and I was wondering if the 14.1" hinge is the same size. I have a dead 14.1" that can serve as a donor, but I don't want to open my 15.0" all the way to find out they ares different sizes. Has anyone did this job previously?
First the hinge metal casing is of different height between the two (since 15" lid is significantly thicker), R5x hinges are even taller.
Second, 14.1" hinge casing width are drastically different between L and R, 15" are symmetrical.
Third, the lid itself is of TOTALLY different material too. 15" T4x lids are ironically made out of weaker plastic with brass threads, whereas 14.1" lids are a solid block of magnesium just with the same rubber paint job outside so you can't tell.
Also, while I have never had any 15" hinge disintegrating on me, I had like at least 3 14.1" T4x left hinges busting on me, and exactly the left one (since it's hollow on the inside to allow both antennae to route through). Kinda ironic that 14.1" T4x likes to have busted left hinges while its competitor Dell Latitude D600 likes to have busted right hinges (too small).
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
Re: T43 hinge sizes
That's what i tought. The laptop is in pretty good shape after i changed the keyboard, but the left hinge exploded. Looking for a replacement down here won't be Easy...
Still, the screen stands up fine.
- 9 Replies
- 510 Views
Tue May 07, 2024 8:05 pm
IBM PS/Note 425 (ThinkPad 350) successful hinge fix & other repairs
by astral » Sun May 12, 2024 1:00 am » in ThinkPad Legacy Hardware - 6 Replies
- 158 Views
Last post by astral
Sun May 12, 2024 5:57 pm
- 1 Replies
- 1830 Views
Sat Dec 16, 2023 1:03 am
t43 wifi doesnt work at all
by kapija » Sat Jan 20, 2024 9:50 am » in ThinkPad T40/T41/T42/T43 Series - 4 Replies
- 1233 Views
Last post by kapija
Fri Feb 23, 2024 7:29 am
