Factory restore VS Clean OS installation
PhoenixR
#1 Post by PhoenixR » Tue Apr 22, 2025 3:00 am
Now this one is an important issue.
I'm sure everyone re-installing the OS had this choice. Every option has it's pros and cons.
Pros
1. Easier to get an installation disk
2. Smaller - it usually consists of 1 disk
3. Faster - both in installation AND BOOTING and RESPONSE TIME
Cons
1. Drivers' mess - after installation you get a whole bunch of undetected hardware with question marks in the Device manager - The most important con
And this could be especially troublesome for models EOLed and thus restricted of any support (like T400 - T510, for example)
2. Not an authentic installation
Factory restore
Pros
1. No drivers' mess - all the hardware is detected alright, usually.
2. No installation mess - potentially unwanted installation issues like for instance switch from AHCI to Compatibility are mostly absent
3. Authentic installation
Cons
1. Harder to get a factory restore OS
2. Bigger in size - takes few disks normally
3. Slower boot and response - the major con
4. Slower installation
From what I've heard IBM/Lenovo actually have issued a special guide for a clean OS installation and here's the link:
http://www-307.ibm.com/pc/support/site. ... MIGR-70665
But the page has been moved or deleted.
So the real questions are:
What are those IBM/Lenovo guidelines for a clean OS installation exactly and what would be the best way to get a faster OS without drivers' mess, especially for EOLed models like T400-T510 etc.?
T400 P9600 8Gb/480 SSD/Hybrid graphics/WXGA+
Re: Factory restore VS Clean OS installation
#2 Post by RealBlackStuff » Tue Apr 22, 2025 3:48 am
Here is the "latest" version from 2009, as found on the Wayback Archive:
https://web.archive.org/web/20090531095 ... MIGR-70665
On oldies like that you're better off installing Linux.
solidpro
#3 Post by solidpro » Tue Apr 22, 2025 6:24 am
There are two more cons with the older factory restores:
1) The media offered freqently doesn't boot or bails somewhere during the installation - because it wasn't created properly, wasn't documented in how to use it (in a way that isn't guessable) or is missing some other part of it's usability (such as a boot disk).
2) The factory restore medium has a very limited and specific method - such as requiring a specific and rare dock, cable or drive.
As a result, and as the older IBM software and drives are mostly widely available, we tend to just use a vanilla OS matching what it would have come with from the factory.
ZaZ
Moderator
Moderator
#4 Post by ZaZ » Tue Apr 22, 2025 12:55 pm
I prefer a fresh install, then making an image, I use True Image, that can be put back quickly if needed and you only have to do the clean install once. I use Windows Update, so never found locating drivers to be messy.
PhoenixR
#5 Post by PhoenixR » Sat Jun 21, 2025 6:08 am
Thanks again RealBlackStuff. :thumbs-UP:
The oldies like that I am on are used not for just browsing or other similar tasks but for correspondingly old windows programs - that's the deal. Otherwise yes Linux would be much better of course
PhoenixR
#6 Post by PhoenixR » Sat Jun 21, 2025 6:13 am
Absolutely true, solidpro - these are 2 more cons, optional, however, appearing sometimes
PhoenixR
#7 Post by PhoenixR » Sat Jun 21, 2025 6:17 am
Sure, Zaz if you're talking about the latest windows. But for the no longer supported windows like XP (especially x64) and even 7, Windows Update could be a problem
Edward Mendelson
**SENIOR** Member
**SENIOR** Member
#8 Post by Edward Mendelson » Sat Jun 21, 2025 6:21 am
This site is an amazingly well-made resource for precisely that problem:
https://legacyupdate.net
PhoenixR
#9 Post by PhoenixR » Sun Jun 22, 2025 11:49 am
Thanks Edward Mendelson I'll give it a try
Users browsing this forum: No registered users and 63 guests
